有没有MA730的SSI通信的代码示例
Hello,I have a question about the Side Shaft. I try the set the BCT value. But it doesn’t work. The encoder output still notlinearity. And whatever i change the value ,the line without any change. my code is down by github and just use ‘writeMagAlphaRegister’
Hello,
Please check enable this function or not
You can see Sensor Orientation part in datasheet.
