问下MPQ2022在 Short-to-battery解除后,输出恢复正常后,寄存器ERR_FLAG_1 D[0]和D[1]里面的记录会保存吗?还是谁寄存器里数值是实时变化的,解除后立即变为0?还是说会保存起来?
如果不使用FT引脚,通过IIC检测Short-to-battery必须实时读取吗?
我看手册里写的如下;
A 15ms blank time is asserted each time the device is enabled when both VIN and EN exceed
their rising threshold or recover from the thermal shutdown or hiccup. The short-to-battery
detection occurs during this 15ms blank time. If the device detects the short-to-battery fault, both
dual LDO switches are latched off or hiccup (based on Reg0x04 D[0] bit set), the /FT pin is
asserted low, and the dedicated bits in the register are set to indicate fault-channel。
在短接到Battery后会进入hiccup模式(软件已经配置寄存器Reg0x04D[0]为1);实际测试短接到Battery后电流还是持续300mA输出,请说明下是哪里设置不对吗
